Jailbreak + Basemap
dkwon
Jailbreak + Basemap
Post by dkwon »
Hi
I just purchased a flash pro for my 2018 fk8 (haven't got it yet) and just have a couple questions...
1. I'm going to instant jailbreak, however, the garage I ordered from said to make sure that I jailbreak before I plug the unit in. I saw in the tutorials that you jailbreak when you plug the unit into the OBD port and computer. I'm a bit confused as to which way is the correct way or if there is one?
2. I have a HKS Legamax exhuast, HKS intercooler with pipingkit, and PRL HVI. I live in Canada and run 91 may contain 10% eth. Which basemap is recommended for my current build? Also, I've heard that the basemaps are a little too aggressive (youtube vids) for the not very good 91 here in Canada (Vancouver BC to be exact). Is there any specific adjustments that I can do for this?
Thank you in advance!
Re: Jailbreak + Basemap
1. Plug in what unit? The FlashPro? You have to in order to jailbreak.
2. 91 octane - int.
Our base maps are tuned correctly. A lot of people like to post negative comments about our tuning so that it makes them look more knowledgeable.
dkwon
Post by dkwon »
Thank you for answering my questions.
1. Sorry I wasn't clear. Yes, I was talking about the FlashPro. Thanks for clarifying, I thought that was the case!
2. Copy, thanks for your recommendation!
david1224
Post by david1224 »
I am also wondering is it safe to run 93 maps with vancouver 94octane gas ? thank you
Yes, as long as they measure the octane as the average of RON and MON.
david1224
Post by david1224 »
thanks for the response, and does hondata has a safe feature that preventing the knock or anything bad happening ? in case the gas is not as good for the 93 maps . ? thanks again
We don't change the knock control logic, but the ECU will retard with knock. If you search you'll find a lot of reports that 94 octane fuel in Canada is about the same as 91 octane in the US, so you may be better using the 91 octane calibration.
david1224
Post by david1224 »
ok thanks you for the advise , i will stay with 91 map for now .
