Cl9 2003 immo a71
Schwx
Cl9 2003 immo a71
Post by Schwx »
It is possible to link the immobilizer of an ECU a71 without going to a workshop?
There's something to keep in mind when using an automatic ecu a71 in a manual vehicle as far as the immo is concerned?
Thanke you
Re: Cl9 2003 immo a71
No, only an Acura dealer will be able to match the key and immobilizer.
Schwx
Post by Schwx »
one question, it's normal that if I not pairing ecu in honda dealer, I will have problem with pairing flashpro with my ecu?
I pairing my ecu tsx with my car with oder diagnostic tool and working in the car without any problem but... Not pairing with flashpro.
Thanke you
Has the CAN adapter harness been installed correctly?
Schwx
Post by Schwx »
Yes
I can see that the ecu it's connected and the Vin number it's detected but the vehicle family and model its unknown
Schwx
Post by Schwx »
information has just been sent to Hondata support as requested.
The FlashPro is communicating with the ECU but the ECU's EEPROM information is corrupt. It could be from cloning the ECU or reprogramming the immobilizer or programming the VIN or the ECU itself could be damaged.
This is also being used in a vehicle that is not supported or designed to work with this.
