ERROR: "Cannot Lock to this ECU because ECU contains an.."
RCR-FK8
Post by RCR-FK8 »
From the picture attached, you can see I can't seem to attach my FlashPRO with my ECU.
Yes - My ECU is new.
Yes - I have successfully applied Jail break
My question is, do you guys already have this file or do I need to send it, as I didn't want to sit in my car for over 120 minutes, as it suggested and it be all for nothing.
Lastly I GRAVELY need this as I am on a limited time schedule to finalize a tune via a contract deadline. Please help and thanks in advance.
Re: ERROR: "Cannot Lock to this ECU because ECU contains an.."
That ECU is supported in the 3.5.8.0 release, which was just released today.
RCR-FK8
Post by RCR-FK8 »
Ok, thanks...How ever I should have you know that I was ABLE TO MARRY THE ECU With the FLASHPRO BUT there was an error during, at start of, flashing which was "HFPF Not enabled on flashpro". THoughts?
RCR-FK8
Post by RCR-FK8 »
HPFP* Is probably High pressure Fuel pump right?
What calibration are you using?
RCR-FK8
Post by RCR-FK8 »
A make shift/in the process of trying to get data to complete in future from Derek Robinson called "Rampage Rev.01" for a turbo swap from Rampage Fab. RS-450
Open 'Mods' and check 'Stock fuel pump'
