Wont start, im out of ideas, getting gray hairs
Posted: Thu May 07, 2020 7:03 pm
by Lordbg0205
90 crx, b18lsv, stock map, I l, snake eater performance 1000cc for break in. p28s300v3. Car wants to start, fires on first hit, then dies, looses injector pulse, check grounds, scoped ckp, cmp, tdc in dizzy td44u, I have spark no issue. looks like car will run fine if pulse was kept going. im out of ideas, ive changed scales, fuel, please someone help. thankyou
Re: Wont start, im out of ideas, getting gray hairs
Posted: Fri May 08, 2020 2:19 pm
I would recommend that you try the ECU on a known working vehicle first to see if it will run with their calibration. If it does, then it sounds like you have some kind of wiring issue in the vehicle.
Posted: Sat May 09, 2020 1:05 pm
by civic EK sir
from your data, it shows the AF 10.2 look like the fuel is to mutch and it will kill your spark plug
the thing you need to check
did you set inj data?
your map sensor set as 4 bar?? or stock map
do you hear the fuel Pump priming?
from online ---> test ECU output
Regards
Posted: Sat May 09, 2020 5:16 pm
by DaX
I had a similar issue and it ended up being my MAP sensor. Verify that with key on, car not running that your MAP is showing close to 0"/psi in SManager. Mine was showing 24" vacuum when it should have been showing 0" and it was doing exactly like you described. I replaced the sensor and everything ran as intended.
