lean protection
panxgee
lean protection
Post by panxgee »
Hi there, i've got a k20a2 hondata v4 pra ecu and trying to activate lean protection but its grayed out? Do i missed something. Wired my aem wideband x series 30-0300 to the ecu analogs, sensor gauge reading the same as the ecu, select external wideband on closed loop operation, put details on analog inputs, did i missed something that will grayed out the lean protection? cheers
Re: lean protection
ou cannot run closed loop form the ECU analog inputs. You can only run closed loop if you have the wideband input to the K-Pro analog inputs.
panxgee
Re: lean protection
Post by panxgee »
yes sorry, i've wired it aem wideband to kpro board analogs using the wire supplied GC98401158.
Re: lean protection
Post the calibration as well as datalogs showing the issue.
panxgee
Re: lean protection
Post by panxgee »
stock1.kal
stock1.kal
Re: lean protection
The PRA does not have lean protection. This is only available for the PRB ECU.
