lean protection
Posted: Mon May 11, 2020 2:04 pm
by panxgee
Hi there, i've got a k20a2 hondata v4 pra ecu and trying to activate lean protection but its grayed out? Do i missed something. Wired my aem wideband x series 30-0300 to the ecu analogs, sensor gauge reading the same as the ecu, select external wideband on closed loop operation, put details on analog inputs, did i missed something that will grayed out the lean protection? cheers
Re: lean protection
Posted: Mon May 11, 2020 2:31 pm
ou cannot run closed loop form the ECU analog inputs. You can only run closed loop if you have the wideband input to the K-Pro analog inputs.
Re: lean protection
Posted: Tue May 12, 2020 3:00 am
by panxgee
yes sorry, i've wired it aem wideband to kpro board analogs using the wire supplied GC98401158.
Re: lean protection
Posted: Tue May 12, 2020 10:52 am
Post the calibration as well as datalogs showing the issue.
Re: lean protection
Posted: Wed May 13, 2020 1:47 pm
by panxgee
stock1.kal
stock1.kal
Re: lean protection
Posted: Tue Jun 02, 2020 11:33 am
The PRA does not have lean protection. This is only available for the PRB ECU.
