map sensor reading boost engine off
Aliecb7
Post by Aliecb7 »
vehicle - 1990 accord
engine - is f20b using stock map sensor on tb
tried the factory map on firewall reading 20 to 22 psi boost same with tb map sensor tried another tb map sensor same thing car will not start and run its flooding out
Re: map sensor reading boost engine off
If a MAP sensor is wired incorrectly even for a instant, it will damage it and it will not read correctly.
When was this last working?
Aliecb7
Post by Aliecb7 »
The factory map on firewall was working fine just before I pulled the motor to turbo . The map was never taken out it was left in the car it has its own factory wiring straight to ecu
Aliecb7
Post by Aliecb7 »
If I unlug the map sensor it goes straight to max boost
Double check the wiring, if it was fine before removing things from the engine bay. Try the ECU in a known good vehicle to see if it reads correctly.
Aliecb7
Post by Aliecb7 »
will try that today or tomorrow thank you
