Cam/Crank s2000 Harness Pinout
sfilardo
Post by sfilardo »
I had to change the crank and cam sensors for kpro in my s2000 to Hall Effect sensors. Does anyone have the pinout for the harness/connector that plugs in to the kpro? (to help identify the power/ground and crank/cam signal wires)
Thanks,
Steve
Re: Cam/Crank s2000 Harness Pinout
Is this the K-Pro specially modified for use with the S2000?
sfilardo
Post by sfilardo »
Yes. The sensors for the crank and cam were changed out and the supplied harness was plugged into the last connector
You must use the parts listed at: https://www.hondata.com/kpro/kpro-s2000
They plug in directly to the harness supplied.
