Radiator Fan always on
Semin1907
Post by Semin1907 »
i had the same issue . radiator fan is always on and do not stop . I checked ethanol input mod and uncheck use second radiator sensor but same. And also when i want to save ethanol input mods to a calibration , it wont save . everytime i have to make from beginning.
Re: Radiator Fan always on
What vehicle and ECU? What calibration? Do you have a flex fuel kit installed? Does it read ethanol content in FlashProManager correctly?
Semin1907
Post by Semin1907 »
Hondata wrote: Fri May 15, 2020 12:59 pm What vehicle and ECU? What calibration? Do you have a flex fuel kit installed? Does it read ethanol content in FlashProManager correctly?
Hello
I have FK8 International(ECU VIN SHHFK8770HU000935): . It doesnt matter what calibration you choose(Flexfuel map ,91 octane map ..). I think we have to check or uncheck some mods and options in Misc Parameters . Yes its installed and i can read ethanol content .
What ECU do you have? E13, E23?
Semin1907
Post by Semin1907 »
G03
With the FlashPro plugged into the vehicle and ignition on use the 'send feedback function'.
Semin1907
Post by Semin1907 »
Sent it yesterday .
Under what name? Did you link to this thread? Otherwise I won't be able to find it.
Semin1907
Post by Semin1907 »
email : gsemin35@gmail.com
Subject / description : Radiator always on
FP Serial : FP-CTR-FK8-INT-370040
VINN : SHHFK8770HU000935
We do not have any reports from you. What about the calibration and a datalog as well?
Semin1907
Post by Semin1907 »
2.5datalog0006.fpdl
Hello again ,
Here is the datalog . I dont think its because of any calibration , i think we have to check or uncheck something in Misc Settings
You must post the calibration you have uploaded.
Tested here and it is ok. The only thing I note is that you're running ethanol free fuel.
If you'd like us to investigate further post some of the information we requested.
