97 civic s300 Bogs when downshifting
VampR
Post by VampR »
hi everyone im glad to be part of the forum maybe i can get some help ,
setup
1997 civic hatch
b16a, blox intake manifold, aem intake , dc 4-2-1 header, full exhaust, skunk 2 tunner 2 cams, buddy club dual valve springs and p-1 retainers. gsr trans stock fuel system stock fuel pump.
Here is the issue i had it tuned on crome and car ran fine no issues, i decided to run s300 and got it dyno so the car made 165hp and 111 tq ran good after the dyno. now i know the guy that tuned it knows what hes doing i dont want to say any names cause it might be something on my end or a setting at s300 so if i am in 5th gear and down shift to 4 or even 3 gear car bogs then quickly jumps into the tune i noticed it does this when its cold is this normal should i remove my mishimoto thermostat and install the oem i think running cold is the issue but isk im lost can anyone help me out
Re: 97 civic s300 Bogs when downshifting
IT could be an issue it is running too cold. You may want to discuss the issue with your tuner.
