The flashpro never upload a calibration
Neopoket
Post by Neopoket »
Flash pro serial FP-R18-US-50770
Flashpro manager version 3.5.9.0
Civic 2007 AT stock
Ecu 37805-RNA-A65
I register the flashpro with hondata and lock to the ecu
When i trie to upload a calibration never upload and say
The last flashpro upload failed.
Failure information: code 0x7F step 13 address 0x000000
I cant return the ecu to stock to unlock from vehicle
Neopoket
Re: The flashpro never upload a calibration
Post by Neopoket »
Ecu is 37820-RNA-A65 i miss type sorry
This ECU appears to have been programmed in some other way that was not done by FlashPro.
Neopoket
Post by Neopoket »
Ok i understand how i can proceed to unlock from the ecu i really want use the flashpro. And i cant used it
Neopoket
Post by Neopoket »
Spunkster wrote: Mon Jun 01, 2020 1:02 pm This ECU appears to have been programmed in some other way that was not done by FlashPro.
I buy this ecu from a junkyark and buy the flash pro to use in my car but when i lock to the ecu i never can upload a map
I'm sorry, but the ECU you have cannot be used with FlashPro. You will not be able to use this ECU.
Neopoket
Post by Neopoket »
No is locked i can't unlock.... i want unlock from the ecu to can use the flashpro in another ecu
Neopoket
Post by Neopoket »
Spunkster wrote: Mon Jun 01, 2020 1:16 pm I'm sorry, but the ECU you have cannot be used with FlashPro. You will not be able to use this ECU.
The flashpro is locked to this ecu.. i want to unlock to use in another ecu but don't let me unlock.. how i can do to unlock because i want use the flashpro in another ecu
