Won’t datalog correctly
Chrissq5
Post by Chrissq5 »
So I’m version 3.6.0.0 and I’ve been trying to do some logging. So once I hit the datalog button I’ve noticed that the light stays solid instead of it flashing which I know it normally flashes. And once I click the button again and go check if it logged. It’s in the datalog page but the datalogs for example only have 1920KB when it usually has about 72,320KB when I do a 3rd gear pull. I want to put that I don’t have my traction off because one of my TPMS aren’t working so I’m not able to take traction off but I don’t know if that can cause the problem of the datalog not being completed.
Re: Won’t datalog correctly
Have you tried deleting all datalogs and trying again? Datalog size will vary depending on the length of the datalog. TPMS will have nothing to do with datalogging.
Chrissq5
Post by Chrissq5 »
Yes I have deleted all the datalogs and it still does the same thing
Chrissq5
Post by Chrissq5 »
Spunkster wrote: Fri Jun 05, 2020 3:47 pm Have you tried deleting all datalogs and trying again? Datalog size will vary depending on the length of the datalog. TPMS will have nothing to do with datalogging.
Yes I have deleted all the datalogs and it still does the same thing. Do you think it can be an update issue? Cause I recently updated the flashpro and once I did, it started to do it.
