will a flashpro tune work
larrymenze
Post by larrymenze »
I have a j32a3 that I added HFPCs and a j37 intake and throttle body . It has j pipes and cat back xlr8 exaust. Base tuned with flashpro .runs super. Since adding the tb and HFPCs Im getting an air leak code. loads of carb cleaner shows no leaks. slow to come down to normal idle. with the increased flow do I need a custom tune?
Re: will a flashpro tune work
I would recommend that you try putting the stock throttle body back on and see if that resolves the issue.
