rsx k24a2 swap
Abhi
rsx k24a2 swap
Post by Abhi »
Hi,
I swapped k24a2 in my rsx.
What calibration should i use from new calibration?
I selected tsx04-05 stock.cal in the rsx (type s)- PRB
But now i have 2 error codes:
P1259- VTEC System Malfunction (Oil Pressure Switch)
P1166- Heated Oxygen Sensor Sensor 1 (Primary HO2S)
Any suggestion would be highly appreciated. Thank!
Re: rsx k24a2 swap
What ECU are you using this in?
Abhi
Re: rsx k24a2 swap
Post by Abhi »
Hi,
It is a PRC ecu.
Fixed the error (P1259) by disabling the Vtec oil pressure switch.
P1166 still pops-up. Is it because it's a JDM ecu?
Also, the ignition timing fluctuates at idle, i think that is a part of Honda's idle control. But when i switch the A/C on, the engine drops rpm significantly from 1000rpm to 500rpm or below and then back to normal.
Re: rsx k24a2 swap
The PRC uses the same sensor as a PRB, so if you have that error there may be an issue with the sensor itself.
The ignition will fluctuate at idle as that is how it controls the idle.
Abhi
Re: rsx k24a2 swap
Post by Abhi »
Hi,
Ill replace the sensor then!
Thanks alot!
