Need new u4 chip
jaybonics
Need new u4 chip
Post by jaybonics »
Burnt fb4 and u4 everything works except laptop connects untill it says unrecognizable USB . On the ecu end I only get a red light no green I can start and drive car . Just need to know what the ferrit to buy is and the chip or black box type thing that has 3 going in and 2 going out on other side . See attached photo
jaybonics
Re: Need new u4 chip
Post by jaybonics »
I'm sorry, but we do not give out component info. If it has burned the whole board will have to be replaced. You will have to upgrade to the version 4 as the version 3 is no longer offered.
jaybonics
Post by jaybonics »
I have kpro v3 can I get an upgrade and how do I get this all too you do I need to fill something out I wanna just upgrade then to v4 thanks
The form can be found at: https://www.hondata.com/downloads/kpro4 ... e_form.pdf
Keep in mind the ECU may be damaged as well.
