VSS Help!!!
ivtec_alot
VSS Help!!!
Post by ivtec_alot »
I have 06 RSX Type-s with just bolt ons, stock tranny and I just got my new kpro v4, I have a VSS issue and vtec is not engaging, I found out thru a datalog, the VSS works in the display tap, but the VSS input is 0 in the Sensors tab and vtec never goes ON in the datalog. I have checked on "countershaft driven speed sensor" (2005-2006 RSX, S2000, TSX) in MISC tab and nothing. The speedometer and millage works just fine, I can't figure this out, maybe the kpro itself is my problem?
Re: VSS Help!!!
Post your calibration as well as a datalog showing the issue.
ivtec_alot
Re: VSS Help!!!
updated info
Re: VSS Help!!!
ivtec_alot
Re: VSS Help!!!
Serial # 53597
