kpro v4 itb
Paulcsm1
kpro v4 itb
Post by Paulcsm1 »
I'm having trouble with my setup I've just fitted a kpro to my car
it k20a
ITBS
my map sensor is just to atmosphere
when driving on track it drives ok until i go full throttle and lift off when i get back on the power it has stopped as if the is no fuel
i then have to turn the battery isolator off and back on it all resets until i brake shut off for the next corner
Re: kpro v4 itb
You need the MAP sensor to read manifold vacuum. Typically you connect hoses from all 4 ITBs into a small manifold.
