Ethanol content reading low
iBoost
Post by iBoost »
I'm running the GM/Continental ethanol content sensor wired to the digital inputs on Kpro4.
I have VP X85 fuel and the sensor is reading 78%. Is there a way to calibrate this?
Re: Ethanol content reading low
There is no compensation for this. You can only adjust the fueling compensation and ignitions changes: http://www.hondata.com/help/kmanager/fl ... htsub=flex
iBoost
Post by iBoost »
Thank you for your response.
Would a different sensor offer a more accurate reading? I don't understand why it isn't accurate.
The VP X85 should read as 85%. Otherwise, what's the point?
You could try measuring it using a manual kit to see how accurate it is. Also keep in mind that unless the tank is bone dry it will be diluted.
https://www.summitracing.com/parts/qft- ... _kEALw_wcB
iBoost
Post by iBoost »
I did have regular in it for initial startup. I drained the tank but perhaps there was still enough in the lines to throw the numbers on the X85.
13btoy
Post by 13btoy »
Sorry to thread jack but I'm having the same issue. Did you ever figure this out? I can't take advantage of my full tune till it reaches 85%. Today I added more e85 and it reached 81 then slowly dropped down back to 78%
Thanks, Ed
