Error code, hesitation on idle, fan runs constantly, high idle on start
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
KFactor
Post by KFactor »
2019 Accord 2.0T AT w/ Sirimoto flex fuel kit, 41.8% is current ethanol reading mixed with premium (92). I datalogged on a long drive, and would have submitted this via the flashpro manager but the file is too large and I don't know how to make it any smaller.
Hesitation while cruising: I've noticed this only happens at below 3000-ish rpm, and it does it randomly, but often enough to be concerning
Error code: P2183 - I've included a screenshot for "misc" settings as I can't find solid guidance on what should/shouldn't be checked. I left it as the default when I created the calibration.
Fan running constantly: It literally doesn't turn off at all, regardless of whether I'm using the air conditioning.
High(er) idle on cold start: It doesn't match the tables in the configuration, and will idle at 1700 for a couple seconds. Not really sure why.
Any help is greatly appreciated
Re: Error code, hesitation on idle, fan runs constantly, high idle on start
You must disable the second ECT as that is being used by the Flex fuel kit and will cause issues with the fan if it is not disabled.
KFactor
Post by KFactor »
A little late, but thank you for the answer. That fixed the issue as I'm sure you already know since the base flex calibration now has that disabled.
