A/F Ratio Oscillation
K20Elite
Post by K20Elite »
Hello,
I was in the process of having my car E-Tuned and have run into A/F ratio Oscillation issues. I will attach a graph and can provide datalogs as well.
My mods are PLR Intercooler / PRL Inlet pipe / PRL Charge pipes / PRL HVI / RV6 Catted exhaust /RV6 Frontpipe / J's Exhaust
I thought there may be a leak in the inter cooler and changed out to a new one - oscillation is still there.
Please help if you have possible solutions.
Thank you!
Re: A/F Ratio Oscillation
Unstable air flow over the AFM, fuel pump limiter enabled, bad o2 sensor. Also a 2nd gear run is not going to be consistent because of TC/VSA.
K20Elite
Post by K20Elite »
Hondata wrote: Sat Jun 27, 2020 1:02 pm Unstable air flow over the AFM, fuel pump limiter enabled, bad o2 sensor. Also a 2nd gear run is not going to be consistent because of TC/VSA.
Thanks for the response, what could cause unstable airflow over the AFM? I will look into the O2 sensor, this happened kinda randomly so assuming maybe the O2 sensor was damaged some how.
Unlikely to be the o2 sensor. Do you have the fuel pump limit enabled?
K20Elite
Post by K20Elite »
Hondata wrote: Sun Jun 28, 2020 2:49 pm Unlikely to be the o2 sensor. Do you have the fuel pump limit enabled?
Fuel pump limit is not enabled
Kenneth12
Post by Kenneth12 »
Hello
Im having same situation with my AF, there is some strange oscillation and I have made the following checks based on your post
Corrected AFM
Fuel pump limiter is not enabled
O2 sensor, I have no reason to believe it has gone bad
No traction control is enabled during oscillation time
Honestly I cannot understand why this is happening or how to correct it
I have made a lot of logs in different conditions (cold IAT2, hot IAT2, even tried different fuel brand) and it happens all the time
Could you help me?
I am worried this could damage my engine
Mods: Stock Intake, Stock Intercooler, PRL exhaust, Greddy frontpipe and catback
From your datalogs you are not experiencing the same problem as the OP.
Kenneth12
Post by Kenneth12 »
Hondata wrote: Sun Sep 06, 2020 8:19 pm From your datalogs you are not experiencing the same problem as the OP.
Could you please help me to find the reason of why my AF is not stable????
The AF looks normal to me.
Kenneth12
Post by Kenneth12 »
Hondata wrote: Mon Sep 07, 2020 8:11 am The AF looks normal to me.
This is another example ... im worried about this behaviour
Even air charge is making oscillation
I have seen many other logs and I cannot find this type of behaviour
Am I making a mistake with my calibration?
how can I improve this behaviour?
Centripetal
Post by Centripetal »
Perhaps, I can help by bringing you through the process I used to look at your log. At around 10:00 in the datalog I noticed something interesting. I've marked the points of interest 1, 2, 3.
1 - Decrease in AFM ~2% while throttle plate is 99% open
2 - Increase of AFM ~2.5% while throttle plate is 99% open
3 - ECM is reacting to something because throttle pedal is 100% and throttle plate jumps down to 55%
Then I toggled through the templates until I saw something that could be a possible cause. It looks like traction control was kicking in.
It looks like you're getting wheel slip around the time these oscillations occur.
jpierro79
Post by jpierro79 »
This a know problem at around 4.7 volts fuel oscillates uncontrollably. It’s in the MAF scaling. I’ve already fixed a lot of cars using a MAF scaling I built just for this.
The problem is a couple of the values translate to positive them negative trim correction which makes the afr oscillate cause the ecu is trying to see what fuel will fix it. You can NOT just add to MAF scaling I had to literally break down the incremental increase to find the errors in it. It takes many hours.
Cars on meth or port do not have this issue because trims stay negative.
sloth4urluv
Post by sloth4urluv »
jpierro79 wrote: Wed Feb 03, 2021 2:15 am This a know problem at around 4.7 volts fuel oscillates uncontrollably. It’s in the MAF scaling. I’ve already fixed a lot of cars using a MAF scaling I built just for this.
Do you mind sharing the AFM table?
I am interested to see what kind of changes you made.
One thing I’ve noticed but am not sure if it is related yet, but around the voltage that I oscillate at there is a step change in the first derivative of the AFM table.
(Derivative)
(AFM Graph)
I have smoothed it out but haven’t gotten a chance to test it yet.
ttking885
Post by ttking885 »
Kenneth12 wrote: Sun Sep 06, 2020 8:04 pm Hello
Corrected AFM
Could you help me?
your air charge values are falling into a leaner cell on the minimum lambda tables.. thats why yours is jumping around.
Kenneth12
Post by Kenneth12 »
this means I should close the value gap between the cells in the minimum lambda tables??????
or should I adjust air charge value???
ttking885 wrote: Sun Jun 20, 2021 2:31 pm
