Aux output not working
EP34ME
Post by EP34ME »
Hey guys , I've got a s300v2 in my eg and have converted the car to an electric power steering pump. It is connected to the hondata through a relay which is switched by the A15 Acc pin . The issue I'm having is that when i set up all the parameters to switch it on it still doesn't work. When i click on the output test however it works properly. All i want it to be set as ,is when the engine goes over 500rpm (engine starting) it will turn on the electric power steering.
Any help would be greatly appreciated
Re: Aux output not working
Without the calibration and a datalog showing the issue it's hard to say what it might be.
