s300 v3 sensor issues?
decdec
Post by decdec »
Hi,
currently have a s300 v3 in a p28 for a turbo b16, i am experiencing a strange issue where on cold start the s300 is reading 150deg for IAT and ECT:
https://imgur.com/a/l1LBmuj
This is preventing the fuel pump from priming and being able to start the car.
However If i leave the ignition on for 10-15 minutes eventually the sensors start reading correctly, the fuel pump primes and the car starts and drives as normal.
once the car is warm if i turn the car off and on it operates as normal and i cannot reproduce the issue again unless the car has been sitting for a few hours.
I am not an auto electrician an do not have access to the person who tuned this car, can someone give some advice on how i would go about diagnosing this issue.
The car also has a burton cop kit installed so just swapping ecu's around is not that easy and i do not have access to another one to test anyway.
Thank you.
Re: s300 v3 sensor issues?
IT could have something to do with what has been modified in the ECU. Have the capacitors in the ECU been replaced?
decdec
Post by decdec »
i have no idea but probably they have not.
I would recommend that you replace the capacitors before doing anything else.
https://www.hondata.com/products/access ... acitor-kit
decdec
Post by decdec »
ok will do and report back
