Kpro4 Bluetooth
Bmatt2020
Kpro4 Bluetooth
Post by Bmatt2020 »
Has anyone had the issue where the Hondata Complete App (also did it on the older Hondata Mobile App) would freeze and not display anything in real-time? Once it freezes, if tried resetting the bluetooth on my phone, and re-initializing the app connection but it doesn't come back. The only way to get it to come back online would be to turn the car off for a bit and restart it.
Re: Kpro4 Bluetooth
Where is your ECU located? What lid is being used on the ECU?
Bmatt2020
Re: Kpro4 Bluetooth
Post by Bmatt2020 »
Ecu is located in the factory RSX location using the factory ecu lid.
Re: Kpro4 Bluetooth
Try removing the lid and see if that helps.
Bmatt2020
Re: Kpro4 Bluetooth
Post by Bmatt2020 »
Are you thinking it’s blocking the signal or causing it to overheat? Have you heard of this happening before?
Re: Kpro4 Bluetooth
It could be interfering with the signal.
Bmatt2020
Re: Kpro4 Bluetooth
Post by Bmatt2020 »
Ok Ill try it and report back.
Bmatt2020
Re: Kpro4 Bluetooth
Post by Bmatt2020 »
I've removed the cover from the ECU and I'm still having the same problem. After it froze, I left the app open and it eventually came back online after about 10 minutes of driving. I've tried it 3 times with the cover removed. Any other suggestions?
Re: Kpro4 Bluetooth
If it is reconnecting on it's own, it sounds like it could be the device it is connecting to that is the issue. Have you tried a different device?
Bmatt2020
Re: Kpro4 Bluetooth
Post by Bmatt2020 »
I tried my iPad this morning and I get the same result. It doesn't show that its disconnecting bluetooth wise, it just seems like the bluetooth data just freezes. If I restart the app on both devices, its able to connect, but it just shows the same frozen data.
Re: Kpro4 Bluetooth
Are you using resistor or non-resistor spark plugs?
Bmatt2020
Re: Kpro4 Bluetooth
Post by Bmatt2020 »
Resistor type. NGK 2669
Re: Kpro4 Bluetooth
From Help, About, what version of KManager are you using?
Bmatt2020
Re: Kpro4 Bluetooth
Post by Bmatt2020 »
4.4.3.0
Bmatt2020
Re: Kpro4 Bluetooth
Post by Bmatt2020 »
I just noticed today when data logging, it froze again. Both Bluetooth and laptop connected. This was after the 4.4.4 update.
