DW300c low pressure fuel pump
ayau
Post by ayau »
I realize that Hondata sells a solution to resolve the factory fuel system limitation. However, for those that are just looking for a small increase in fuel (~5% reduction in pump duty cycle) and don't want to spend money for the complete kit, will the DW300c resolve this?
Or is there a mechanical limitation on the factory high pressure pump that would prevent more fuel from flowing even if the low pressure pump can supply more fuel? In other words, if you replaced the factory low pressure pump with the DW300c, would the duty cycle numbers read exactly the same as the factory pump?
Thank you.
Re: DW300c low pressure fuel pump
Changing the low pressure pump will not have any effect.
long_chris@me.com
Post by long_chris@me.com »
Would the DW300c LPFP work as a replacement for the HONDATA fuel systems LPFP?
