Open Loop - IAT compensation table
Lyle_57IAL
Post by Lyle_57IAL »
Hi guys,
Would like to request some further detail on the IAT Compensation. Currently the compensation is only base on Intake Air Temperature, however this is problematic with idle when restarting the car with heat soak.
If this table was 2 dimensional (X-Axis Temperature) ( Y-Axis Throttle position).... you could ensure that there were no background IAT negative fuel corrections at idle.. which always makes the car run leaner and Hunt etc.
Other ECUs have the capability such as Link or Haltech. Would be good if Hondata added this as i cant see it being a large software update
Cheers guys
Re: Open Loop - IAT compensation table
I do not believe that is something that can be added.
Lyle_57IAL
Why, there are other parts of the software that are designed in such a way
The ECU has a finite amount of memory and processing power.
