Low Boost/Hi Boost
Bmatt2020
Low Boost/Hi Boost
Post by Bmatt2020 »
I was wondering if there are certain parameters that need to be met before Kpro will accept the changeover from hi/low boost? For example, If I have to come to a complete stop, wait a few seconds etc... The reason I ask is because I've used the switch successfully recently, but for some reason it's not working right now. On low boost I have it set to 8 across the board. On hi boost I have it set from 1-2 to 8psi and 3-6 to 14psi but after hitting the switch (while driving) then immediately doing a pull in 3rd I'm still only registering 8-9 psi. Also is there any sort of feedback from the ecu that tells me the ecu can see the switch as being active? I'm using E22 brake switch as my hi/low switch.
Re: Low Boost/Hi Boost
Please post the calibration, and if possible a datalog.
Bmatt2020
Post by Bmatt2020 »
Cal and logs posted. Come to find out, on low boost the boost solenoid is at 41 % (I'm commanding 8psi/30% duty) and on hi boost setting the solenoid is at 42% (Actually pretty close based on boost table).
Are you using live tuning while doing this?
Bmatt2020
Post by Bmatt2020 »
I am not. I would make changes to the file and upload
Bmatt2020
Post by Bmatt2020 »
Should I have been?
You do not have to, it was just for more info.
I would recommend that you go to the online menu, tools and erase the ECU, then close KManager, reopen it and then open your calibration and upload to the ECU.
Bmatt2020
Post by Bmatt2020 »
Ok I erased the ECU and re-uploaded the calibration and it didn't work. I did end up figuring it out though. I had my ethanol boost compensation at 100%...
