CEL No Code
Civic 2016+ 1.5 Turbo
sunworld23
CEL No Code
Post by sunworld23 »
FlashPro Version 3.6.1.0
Calibration: Civic Turbo CVT 2016, +6 psi high octane, EPA/CARB compliant
I have a 2016 US Civic CVT Coupe Touring. After doing a flash, all the indicators eventually went away as expected except the check engine light. I clicked on Error Codes while Datalogging but no codes showed up. Any suggestions? I tried returning ECU back to stock but it is still there.
Re: CEL No Code
Try using Online -> OBDII Diagnostics to find the code.
sunworld23
Re: CEL No Code
This morning I checked and discovered the CEL light was now off. Guess it just needed some time. Will update if light comes back on.
Thanks for letting me know about OBDII Diagnostics!
