93 basemap ok for my setup?
AC_FK8
Post by AC_FK8 »
Did some \datalog 3rd gear pulls and was wondering if everything is running ok?
My set up is 2018 FK8
Mods
PRL intercooler
PRL charge pipes
PRL HVI intake
PRL Turbo inlet pipe
Invidia
AWE tuning Track edition Exhaust /w Front pipe
Hondata Flashpro
Running 93 octane with exhaust and intercooler, improved throttle response map
with these checked off
these are checked off
Remove factory boost limits
Disable secondary o2 for dp
Pump gas 0% ethanol
decrease Knock
Disable Rev hang
Sensor remove for P0101 & P0103 error (I have gotten a CEL error code P0101 before)
Improved throttle response full power 1st and 2nd gear
Traction control aggressive launch
increase turbocharger boost limit
increase turbocharger pressure ratio
Hondata traction control 6% and 6mph
datalog0000.fpdl
Everything is ok with this calibration?
Re: 93 basemap ok for my setup?
Fuel pump is running to 100% between 4000 and 5000 rpm so I would reduce the maximum air charge in those areas.
There is consistent knock under boost so I would reduce the ignition timing by 1.5 degrees under boost.
AC_FK8
Post by AC_FK8 »
Thanks Hondata. Definitely need to dyno custom tune soon
AC_FK8
Post by AC_FK8 »
Also I’m running boostane to achieve the octane to be able to use the 93 basemap. Can too much of it make me knock? I most likely was running 98 octane doing this data log
