S300 problem
henry.lo3
S300 problem
Post by henry.lo3 »
Hi, I have a P06 with S300 installed. I have removed the Pin J12 but I’m still not getting a datalog reading on my ecu. Onboard datalog is off, I also have a CEL on with no code. My S manager is version 2.7.3.0
Re: S300 problem
Your software is out of date, and the soldering on the 14 pin connectors looks sketchy. You may have damaged the through hole plating and it may not have any connection.
