2019 2.0t 6 speed p0139 and p0113 codes
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
Snpxgen
Post by Snpxgen »
2019 2.0t 6 speed
Rv6
Borla catback
Afe intake
Car is custom dyno tuned 290whp and 357wtrq
Running perfect no loss on power but these annoying codes popped up
P0139- o2 sensor slow response Bank 1
P0113- intake air temperature circuit high input
I reset them both and cleaned the intake air sensor with maf cleaner which could of been from the oiled afe intake
Re: 2019 2.0t 6 speed p0139 and p0113 codes
You will need to follow the factory troubleshooting steps for the IAT error, and have you tried disabling the secondary O2 sensor?
Snpxgen
Post by Snpxgen »
Are these errors related to each other?
I received both around 50miles after my dyno tune.
Probably not.
kpthemanatee
Post by kpthemanatee »
bout to install prl exhaust, front pipe and intercooler and im sure ill get a check engine light. they told me to check the secondary o2 sensor off? where do i do that?
It is in the closed loop section of the calibration window.
kpthemanatee
nvm, i found it!
kpthemanatee
is there any in particular i should be changing on the calibration with the intercooler, frontpipe and exhaust installed? trying to maximize power but more importantly reliability.
thanks!
