Kpro vault search and download.
KMR2
Post by KMR2 »
Just wondering if we are able to download files that has been searched for in the vault. I double clicked the file to download, which isn't mines, but can't find the file anywhere. Does it save it to a specific location? or can you only download files you have uploaded?
Re: Kpro vault search and download.
What is the file?
KMR2
Post by KMR2 »
it's a .kal file. I was just searching for a base tune for a stock k24a2 turbo that I could use.
Also, the Kmanager isn't connected to the ECU. Not sure if I need to be connected or not.
When you open a file from a vault search, it opens in the software. You must then go to the file menu and click save as and you can specify where it is saved.
KMR2
Post by KMR2 »
ahhh, gotcha... I didn't see it cause it opened as untitled and didn't even think of opening the tabs. Check the tables/parameter and there is a tune there. Clicked save as and all is well. Thanks for turning on the light for me!
