Ignition Timing Jumps bigtime below 2500rpm
AaronEG
Post by AaronEG »
Hey Guys,
Maybe im Overlooking something but here is the problem
i have been tuning an EP3 with KPRO but unfortunately it does something weird for no obvious reason
the ignition timing jumps back and forth in between 2-30 degrees down low ?
there is no knock control turned on , nothings in the tables and i canf find the reason
for it to do so, tried to upload a stock EP3 Map, same problem
has someone had the same issue ?
Check out the cal and Logfile
LogFileTuning
Re: Ignition Timing Jumps bigtime below 2500rpm
Please see ignition smoothing retard: http://www.hondata.com/help/kmanager/ge ... htsub=gear
AaronEG
Post by AaronEG »
ahhh i overlooked that one , thanks its working flawless now
LogFileTuning
