Qns on Anti Lag Values
KT7788
Post by KT7788 »
Hi Teachers
Good Day
Qns :
Ign Retard , should the input is 10 , Means the true values is -10
And it will bypass the ign setting in the ign map . Am i correct ?
Re: Qns on Anti Lag Values
It will retard the ignition by 10 degrees.
KT7788
Post by KT7788 »
under this function the max values is 64 meaning able to retard to the max 64 ?
I do not think it can mechanically retard that much.
