Nitrous / Aux 1 Fuel & Timing Adjustment
jgadell
Post by jgadell »
Snow Performance water meth kit is enabled via a switch and works flawlessly with the S300 right now. My question is instead of tweaking secondary tables there is the timing and fuel adjustment within the nitrous/aux area. What I gather is these values are "fuel units" so at say 4000 rpm I want to remove 3% fuel and 5000 I want to remove 2% fuel what am I entering. The guide shows values of 100 and 200, I just want to understand before I add or remove some values and it goes crazy.
Re: Nitrous / Aux 1 Fuel & Timing Adjustment
You will have to experiment with the amount of fuel you remove to get it right. This should be done on the dyno.
