b16a with 440cc injectors base map needed
ok so i have a stock b16a with 440cc injectors and a 340lph fuel pump and a block off plate for the iacv i need a base map for my injectors and tune around the iacv i cant aford a dyno tune so im reaching out to you guys for help
- CalibratEd
- Contact:
Re: b16a with 440cc injectors base map needed
Do you have a wideband and can you provide datalogs?
-Ed
-Ed
Instagram: calibrated.tuning
civic EK sir
you can try this map
as Ed says you should have wideband + injector data.
