Check lights after tune on base map
anthonyqtran
Post by anthonyqtran »
Finally got my flashpro and decided to put a base map tune on it figured it wouldnt hurt much(will be getting the car professionally tuned). Chose the one that closest suits what I have done on the car and took it for a test drive, felt great could definitely feel a big difference so decided to keep the tune on for a bit. Was driving regularly and my VSA, traction control, and check engine light all came on at the exact same time. Not sure if this is relating to tune or not but the car still runs perfectly fine.
Mod list includes:
Full race cat back exhaust
Skunk 2 alpha headers
Injen cold air intake
Hybrid racing cmc
Skunk 2 short shifter link
Skunk 2 stage 2 tuner cams
Skunk 2 titanium valve springs
Skunk 2 throttle body
Hondata flash pro
Competition clutch stage 2
Ultra light 8lb flywheel
ACT throwout bushings
Carbon fiber hood
Enkei ekm3
Nankang racing tires 215/40 R18
Skunk 2 lowering springs
Kyb struts
Spec-D headlights
Re: Check lights after tune on base map
Have you datalogged and checked for errors?
FA508
Post by FA508 »
Are you running cold air intake, skunk2 race header and full catback exhaust basement setup from flash pro? Try to do some data log and maybe it will need a proper tune or customer tune for your setup.
