5th gear 7000 rpm after afr rich
Re: 5th gear 7000 rpm after afr rich
I don't understand how 5h gear at 7000 RPM has anything to do with idle. Maybe I'm not understanding your description.
Have you considered disabling the AFM and tuning via Speed density instead(MAP based tuning).
You should try this and see if it works better for you.
