CVT limitation
CRV 2017+ 1.5 turbo
ayau
CVT limitation
Post by ayau »
Honda has a 1,500 lbs towing capacity for the 2017+ CRV. Is CVT reliability a concern for the CRV just like it is for the CVT Civics when increasing torque?
Re: CVT limitation
I'm not aware of any differences between the transmissions.
arnoldod
Re: CVT limitation
Post by arnoldod »
Spunkster wrote: Fri Aug 14, 2020 10:57 am I'm not aware of any differences between the transmissions.
In that case, shouldn't CR-V torque limiter set with 250 nm max torque in mind instead of 260-280 nm in +6 PSI CR-V CVT calibration?
Re: CVT limitation
You'd have to ask Honda that question. I would not tow with a CVT without an transmission cooler.
