Analogue Board
Javcolin
Analogue Board
Post by Javcolin »
Hello,
I have installed my flex fuel sensor to the Analogue board, both the signal and the ground, I will add a Fuel pressure sensor as well, will ground it to this board too so as the signal to AN1,
I can see there are a few inputs but only 2 grounds points, so my question is how many sensors can you wire at each ground point on the analogue board?
Re: Analogue Board
What version s300 are you referring to?
Javcolin
Re: Analogue Board
Post by Javcolin »
Latest Version S300 V3,
That has the sub-harness for the analogue inputs, It has 2 grounds and the rest around 5-6 inputs for different sensors, So if one would like to ground straight to the board. how many sensors could you graound per each ground input?
Re: Analogue Board
These grounds are for the signal, and not mean to be used as power and ground for the sensor itself.
These can be used for any 0-5V sensors you can connect multiple items to the same ground that require a ground for the signal.
http://www.hondata.com/help/kmanager/an ... sub=analog
Javcolin
Re: Analogue Board
Post by Javcolin »
I undertad now,
I wired in my Fuel Pressure sesnsor that required 0-5v, SIgnal to An1 and 0v to one of the grounds on the Analgue Bord, so it is ok,
What about the fuel Flex sensor can you ground it to the Analogue board as well? or that has to be grounded somewhere on the chassis?
Thanks a lot
Re: Analogue Board
That should be grounded on the chassis.
