Kpro - Analogue input Pins
Lyle_57IAL
Post by Lyle_57IAL »
Good Morning Hondata,
Was wondering if there were any pins available on the factory loomb / plugs to use for a analogue input.
Like the S300 / Smanager, OEM pins can be reused to take an analogue signal. ie - D10, D12, D14, B6 .
Are there Original pins that can be used in the Kpro in the same way ? or is the only way to get an external analogue signal into the Kpro via the secondary pigtail on the circuit board (analogue inputs 0 - 7)
TIA
Re: Kpro - Analogue input Pins
The only option is to use the analog input pins on the KPro3/KPro4
