Hondata pros I need traction advice
Sayanythng
Post by Sayanythng »
My issue is the Honda vsa system kicks in retarding ignition causing a backfire when enabled I know this because I’ve disabled one then the other to confine the issue, 2nd gear 5kish. I’m running 9% slip. Should I lower my slip value so hondata traction control can intervene before the stock vsa? Gets annoying disabling factory vsa for hard pulls. I’m running 91 octane map high flow cat improved throttle response 3rd-6th power
Eventuri intake
Rv6 catted exhaust
Invidia exhaust
Re: Hondata pros I need traction advice
Reduce the torque in 2nd gear.
LexieGrayRose_FK8
Post by LexieGrayRose_FK8 »
Quick question since I seen you running the RV6 catted DP....For selection there is no RV6 baseline tune what did you run for a tune selection or did you end up doing a custom dyno tune....I was thinking of selecting PRL DP and Front pipe as a close reference, or is there another option if running a brand which isn't pre selected ?
Any info on this Hondata or OP ?
Thanks in advance
Sayanythng
There is a option it’s rv6 high flow cat.
