MISC PARAM- FUEL ECONOMY ALTERNATOR CONTROL
dvergara
Post by dvergara »
good afternoon hondata.
I have a voltage problem with the 9th gen FB6. The car is running normal at 14v and in one second the voltage drops to 12v .. this stays for one or 2 seconds and then returns to 14v
We already did:
validate that the option of fuel economy alternator control is disabled on the map
battery change
groun revision
single belt change
crankshaft pulley revision
alternator change
Could this be a Map glitch? when the voltage drops to 12v the mix goes to 16..17 AF
Re: MISC PARAM- FUEL ECONOMY ALTERNATOR CONTROL
Without the calibration and datalogs showing the issue it is hard to guess what it might be.
dvergara
Post by dvergara »
Attached MAP and DATALOG with voltage failure
If you go to the Online menu and return to stock, does the voltage do the same thing?
dvergara
Post by dvergara »
tks Hondata.
we already solved the problem. A bad electrical installation was affecting the voltage
