Kpro not showing any sensor data
Jonny7isa
Post by Jonny7isa »
Hi everyone,
Set up:
Kpro V3
2000 Integra Gsr w/ k20a2 swap
Hybrid Racing Conversion Harness
RSX Type S stock harness
Made all the connections needed for everything to work from the conversion harness to the RSX Type S engine harness.
ISSUE
  • [] When i plug the Kpro onto my laptop, and start 'datalogging', most sensor readings are at ZERO
    • [] and according the Kpro, no error codes (which is weird to me)
      • []For the systems under Error Codes, it also says not supported!
        When i try to connect my scanner to the OBD port, it tells me unsupported, like if it doesnt read it.
        My Integra starts up (cranks for a long time until it turns over), and revs up, cluster readings work (RPM, Tachometer, fuel).
Re: Kpro not showing any sensor data
Jonny7isa
Post by Jonny7isa »
Serial Number - Kpro 13175
Software - v4.4.4.0
When was the last time that this was working?
Have you tried the ECU in a known working vehicle?
Jonny7isa
Post by Jonny7isa »
Spunkster wrote: Thu Sep 03, 2020 9:06 am When was the last time that this was working?
The K20a2 and the Hondata Kpro v3 we're taken both off a 2002 Acura RSX Type S. I drove the RSX for a couple of months no problem. Which is why I dont know why its not reading any sensors
Jonny7isa
Post by Jonny7isa »
the K20a2 + Hondata kpro is the swap set up i am using on my DC2 Integra
Have you uploaded a calibration to the ECU since updating the software?
Jonny7isa
Post by Jonny7isa »
Spunkster wrote: Tue Sep 22, 2020 11:37 am Have you uploaded a calibration to the ECU since updating the software?
Yes, I have. But I cant tell if it works since no sensor data appears when 'datalogging'
IF you set an artificial rev limit of 2000 rpm, and upload the calibration, is there a rev limit at that RPM?
Jonny7isa
Post by Jonny7isa »
Just tried this tune attached, and rev'd it (expecting to limit at 2k rpm) but it went past it
and this is what I see
stock.kal
It shows that it is online, but the ignition is off. You should try this ECU on a different vehicle and see if it shows that the ignition is on.
Jonny7isa
Post by Jonny7isa »
Spunkster wrote: Mon Sep 28, 2020 9:21 am It shows that it is online, but the ignition is off. You should try this ECU on a different vehicle and see if it shows that the ignition is on.
This is what it says when the car is actually on
Jonny7isa
Post by Jonny7isa »
And for some reason, once turning off the car, I heard the ECU beep twice (1 min in between each beep) .
Not sure if thats a concern or not
Is this in a different vehicle?
Jonny7isa
Post by Jonny7isa »
Spunkster wrote: Mon Sep 28, 2020 1:04 pm Is this in a different vehicle?
Same vehicle
