Since new update can’t upload a tune
Sayanythng
Post by Sayanythng »
2020 type r jail broken sent the ecu in been using the 91 octane tune before the latest beta update now I cannot upload a new tune with the updated setting Honda type r 2017+ is the only option I get this error
Sayanythng
Re: Since new update can’t upload a tune
I believe is issue is you guys don’t yet have an updated model configuration so what do the 2020 guys do now?
Sayanythng
Update: Tried reinstalling still no luck
Close the calibration then re-open the calibration with the FlashPro plugged in.
Make sure you have the FlashPro plugged in with the ignition in the on position when opening a calibration and it should work.
Sayanythng
Spunkster wrote: Wed Sep 02, 2020 9:26 am Make sure you have the FlashPro plugged in with the ignition in the on position when opening a calibration and it should work.
Flash pro plugged in to Laptop. New calibration configured. Plugged flash pro into car from laptop With ignition on. Same error
post your calibration.
Sayanythng
Spunkster wrote: Wed Sep 02, 2020 11:22 am post your calibration.
not a picture of the new calibration window. We need you to post the actual calibration you are using.
Sayanythng
Spunkster wrote: Wed Sep 02, 2020 4:44 pm not a picture of the new calibration window. We need you to post the actual calibration you are using.
I can’t post one because The flash pro is cleared I’m trying to upload a new calibration.....
First picture shows what
what’s flashed on the ecu
Second pic shows Nothing on the flash pro
We have fixed this issue and are doing another release now.
Sayanythng
Here’s the old calibration but is the one I’m using. I reopened it. And it will download to my pro I just can’t do a new calibration because I get promoted the error
Sayanythng
Hondata wrote: Wed Sep 02, 2020 5:24 pm We have fixed this issue and are doing another release now.
Ok in the next week? Since I have you here the highest octane fuel I have already at the fuel pumps is 92 octane. I notice when I select 92 the drop down says Mexico us 17-18. Is that possible elevation would be the reason for the octane should I try that calibration?
I'd use a 91 octane calibration for US 92. Where do you still get 92 octane?
Release will be done today.
Sayanythng
Hondata wrote: Wed Sep 02, 2020 5:45 pm I'd use a 91 octane calibration for US 92. Where do you still get 92 octane?
Oregon only haS 92 octane from the pump no 93 available
