Always rich on low cam on transition into positive pressure
LstCivic
Post by LstCivic »
On a few different cars I cannot get it to lean out on the transition into boost. Right around 0 no matter how much fuel I pull it doesn't seem to make a difference in the log, there are no sharp jumps in pulsewidth. From column 9 it goes from 13.5 straight to 10.0 in column 10 even if I drop the whole column to lower than column 7 .
Re: Always rich on low cam on transition into positive pressure
Make sure you are editing the correct cam angle map, as it is probably running on a different map then you are editing.
