P30 ecu with knock sensor
bestlap
Post by bestlap »
i'm using P30 ECU with Knock sensor, i can see the knock level and knock retard on Display only, is it possible add Knock table able to change the value for sensitivity and retard?
Thank you!
Re: P30 ecu with knock sensor
That cannot be changed. If you get knock then you need to reduce the timing in the area that knock occurred.
