Indicator of fuel quality (octanes) in datalog
Civic 2016+ 1.5 Turbo
turboroe
Post by turboroe »
Hi guys, can someone tell me if there is a known indicator of fuel quality in terms of octanes, that can be visible in the comparison of data logs?
For example, if I use 87 fuel then a certain sensor or calculated value in the data log would be higher or lower than if I used 97 fuel. Or maybe the average value of some sensor?
Something like the ST fuel trim that tells me if I am running rich or poor.
All considering the same calibration and similar climate conditions.
Re: Indicator of fuel quality (octanes) in datalog
The knock control gives you an idea of the quality of the fuel.
turboroe
Post by turboroe »
Thanks for the reply. I will check my logs.
