FlashPro Manager 3.6.4.0
OkayJunior
Post by OkayJunior »
Installed both Manager and USB Driver. Opened as administrator. Yeah it gives me the pop up window “The FlashPro firmware will be upgraded.” I did the whole disconnect/reconnect usb thing and both driver and flashpro are green checked. I press OK, and I click anywhere and it “Not Responding”
OkayJunior
Re: FlashPro Manager 3.6.4.0
Deleted/uninstalled FlashPro and reinstalled it all over. Working fine now. Can anyone help with a calibration?
2012 Civic Si
Skunk2 CAI
Skunk2 megapower rr exhaust
Skunk2 Header/exhaust
Grams Performance 1000cc Fuel Injectors
Grams Performance 72mm Drive-By-Wire Throttle Body
Skunk2 manifold
OkayJunior
When trying to upload a new calibration a pop up ERROR says “You cannot upload a ‘Unkown’ calibration to a ‘Civic Si 2012 US’ FlashPro
When I click ‘Show Last Upload Status’ it says the last FlashPro upload succeeded.
How are you opening the calibration you are trying to use?
OkayJunior
The regular tab “new calibration” and choose. Is there a proper way?
OkayJunior
Updated to the new firmware. Uploaded a calibration. Car works hella nice than before! Question. Is it possible to upload two calibrations with different cc injectors?
Why would you want to upload calibrations with 2 different sized injectors?
