Hello I'm new to the tuning world.
Im currently finishing up my project.
It's a 90 crx with a k20a2 head on a k24a4 block.
Wondering if anyone can point me in the right direction.
I have my kpro v4 but I'm clueless as to where to start off.
Current Setup:
Prb ecu kpro v4
Using a phanetric ef conversion harness
Skunk2 ultra 2 cams
Skunk2 pro xp valve springs
Skunk2 std size flat race valves
Head has been mildly ported
Wiseco pistons 88mm 14:5 cr
Skunk2 H beam rods
Stock crank
Prb manifold
70mm tb
Oem rdx injectors
OEM k20a2 engine harness
K20z3 trans
Lmk if theres anything else I should add.
K20a2/K24a4 crx
- CalibratEd
- Contact:
Re: K20a2/K24a4 crx
You can start with an RSX type s base tune and modify it for the RDX injectors. You can then tune the fuel and timing assuming you have a wideband.
-Ed
-Ed
Instagram: calibrated.tuning
