CIVIC SI PROBLEMS AFTER DYNO TEST
Civic 2016+ 1.5 Turbo
CR3WZAT
Post by CR3WZAT »
Hi guys.
Well i have a 2018 Civic SI Coupe, yesterday we test the car on the dyno to get the numbers stock and compare in the future with the mods. After the test the car gime a lot of messages in the cluster, like when the car dont have battery, so my question its if that limp mode restrict power of the car? that errors disappear after drive some minutes? need a diagnostic tool to erase? i have a flash pro, so i can use a stock base map with traction controll off? or just do the test with the pedal dance? the pedal dance give any power restriction?.
Regards.
Re: CIVIC SI PROBLEMS AFTER DYNO TEST
If you drive the car around the errors will disappear.
For the dyno you need to do the pedal dance. Disabling the traction control don't do anything.
